trackday killed the engine - ideas please
  TVR Cerbera
Hi,
I killed my engine at the weekend on a trackday, or so i thought
I missed 3rd gear and possibly over reved. engine cut out and wouldn't restart, but turns over like the plugs are out. suspected no compression / bent valves. no compression confirmed by testing. Prepared myself for the worst.
however, i did some more tests, pressure tested the cylinder, through the spark plug hole with an airline, and if i get the engine in the right place on each cylinder, it holds pressure! the pressure will even rotate the engine. however i did notice it only rotated it a small amount before the inlet or exhaust valves open and let the pressure out.
now i'm stuck for ideas as if i had bent my valves it wouldn't hold pressure. is there a possibility the cam timing is wrong, eg just jumped a tooth or pulley slipped on the cam? or something else?
thanks Daz
  172 Race Car
worth checking the timing by the sounds of it.
You wont need the tools to do a quick check. Just take the blanking caps out and line up the tdc mark on the gearbox/flywheel. If its out more than a little you will see it by eye.
As you say if its holding a presur at a certain ponit then maybe the valves are ok. Dont you run different cams?
  TVR Cerbera
yeah 422 catcams. surely with that cam and high comp pistons, if the cam timing was out, i'd have valve/piston contact?
  172 cup
if its slipt one or two teeth you might of got away with it. And yes this is possible from missing a gear
  172 cup
the more teeth it has slipt the more likely it is to give a zero compression reading. Shame that only spotted you turning off pelham bridge other week. Think you saw me too.
Take the two cam seals out and see if you can get them to line up
  TVR Cerbera
Checked the timing..............bottom pulley at TDC, Exhaust cam 1 tooth out and Inlet cam 90 degrees (sommat like 8 teeth) out! When turning over by hand there is piston to valve contact but only just.
So i retimed it ( gonna change belt and tensions before i start it) and both cams seem to be about 1/2 tooth out. Whether this is due to it not being properly timed before or the pulleys have slipped.
mmmmm
Daz
  ClioSport 172 Cup
How do you remove those blanking caps without destroying them? Last time i took one out i had to puncture a hole in the centre and pull it out that way.
Samuel
  Dodgy one
TBH mate if theres been valve contact with the pistons i wouldnt refit another belt and start it up again, It will tap its tits off and in time drop the valve which will make it a more expensive repair than you have already!
you just have to undo the first few rows of bolts slightly to raise the cam cover at that end and you will be able to pop them out undamaged.
  TVR Cerbera
The valves aren't damaged because it does a leak down test fine
  C63 AMG, F430 & 172
How the f**k did it slip if you missed a gear? mine used to bounce off the limiter all the time and had no issues.
Didn't you say you were down on power a while ago, running only 210hp? Maybe its been a gradual thing?
  TVR Cerbera
lol i wish. my soft cut (ignition) is at 8k. my hard cut (fuel) is at 8.1k.
I missed 3rd, nailing it out of a bend keeping up with an expensive TVR, and he wasn't getting away! basically floored the throttle from about 6 - 6.5k thinking i had got third, but i'd hit in between 1st and third! so no grinding gear to make me think i wasn't in! I couldn't tell you what revs i hit, because i've never floored it in neutral before, but believe me it revs quick enough just touching the throttle!
yes my power was down and the exhaust cam nut was loose too! haven't got the cap of the vanos pulley yet, it's too tight! (meant to be torqued to sommat like 15 ftlbs!)
so i'll keep plodding on and see what other horrors i find!
  TVR Cerbera
Samuel
That's how i take them out, they are £12 from stealers for the pair!
Take the cam cover off ;)
Don't think you can.
true, but then you have to reseal the cam cover, and i'd rather waste £12 than disturb that, cam belt, both pulleys etc, etc. cos you can't get the cover off without taking the pulleys off, and you may not get a good seal without doing so
thought they are meant to be replaced everytime
That's what i thought
i was told by quite a few people on here if they are undamaged when removed (ie removing whole top cover) they can be reused without a problem
but meh! I guess its only £12. Mine are re-used and they have been fine.
  TVR Cerbera
Yes i agree if you are taking the top end apart and they are undamaged, then why not, i'm not, just doing cambelt change and timing so i have to replace them
  TVR Cerbera
I'm not 'hoping for the best', it will get done properly, TBH if it had been done properly in the first place this may well of never happened, but that's a different story.
Prepare to be suprised.........maybe. TBH i don't know what has been done yet. the engine still tuned over by hand with no resistance eg valve contact and the cylinders are sealing with no leaks.
the valves cannot be bent if it's sealing and it turns over freely by hand , so no contact.
we'll see
  M235i / 172
You said in an earlier post that; turning over by hand you can feel the valve's just touching the piston? But you've just said the opposite.. so which is it? Personally i'd whip the head off and ivestigate, no more turning it over, even by hand. Thats just me though.
  Evo
Sounds like damage is already done lol, turn it over all ya want.
Does it start? or turn over on the motor?
I havent a clue what it could be just interested on how this ends up...
  TVR Cerbera
Sorry i do apoligise, i got confused with the resistance felt at the top/bottom of the piston stroke and actual valve contact
  TVR Cerbera
I hate to say this, but read your last sentance first and then ask yourself why you stated the other 2 comments....... It doesn't start, it has no cambelt on it! There has been no sounds to indicate damage! and i will turn it over all i want because even if there was damage, it aint going to make it worse!
I can't understand you guys sometimes, if you'd come across an engine, unknown history, good compression, runs fine etc, would you waste best part of £500 stripping it to make sure it's ok? Surely if i have good compression, I can't have done any damage?
  M235i / 172
I wasn't having a go mate, but just from what you have said in earlier posts about what happened and the problems you had. Even if it now tests ok compression wise *I* would still have it apart.
What ever happened wasn't good and the next thrashing it has may well be fatal for the engine.
Like i said not having a go, just my 2p :)
  TVR Cerbera
i know mate, np
  C63 AMG, F430 & 172
I would re time it up on the old belt, give it a good 10 turns by hand, see if it feels ok.
If not, strip it down!
If all is good then wip a new belt kit on, only cheap!
  TVR Cerbera
i'm in the middle of timing it with old belt and new belt is on it's way. Trying to get a camera to look down cylinders this weekend
  TVR Cerbera
Right a bit of an update:
Got the new belt on, and running - however top end really tappy, and knocking noise from down below on overrun. buggar
got the cams out again, to find, all the lifters had locked solid! sorted that, back together again, tapping has gone but knocking is still there!
come on then whats yours guesses and i'll tell you what else i've found without taking anymore of the engine apart ( a clue)
  53 Clio's & counting
how low is the knocking noise? its gotta be top end related im guessing if you havent stripped it down further
