Tracking, i'm so confused by what to go for
len_beach
Car  E92 M3,172 track car
I will be having the toe angles reset sometime this week but need to know what to ask for. I've been reading through Edde's spec's but the details just confuse me, 2 44' this, 1 35' that.
The car is a phase 2 172 lowered on Sportlines fitted with Cup Turinis.
Do I go for FF settings, Cup settings or a custom angle as Fred suggested I go for slight negative?
We discussed this a while ago Fred, I've just found the thread. Do you say -0,05?
What does a 172 and a Cup run?
Is the negative suitable for road use or will I scrub tyres out in no time?
You can only adjust the toe in and out with normal stuff unless you use cmaber correction bolts to adjust the fornt camber and shim to adjust the rearr.
The techie will understand those figures when he goes to setup your car.
It will just be the toe Edde.
Would you recommend I go for the standard settings 1 35' i'm guessing, Cup 2 44' or the slight negative?
Any ideas guys? I'm hopefully getting this done tomorrow.
Do I go:
Standard,
Cup,
Fred's slight negative?
