Tracking...?
Car  RenaultSport clio 172 mk2
Whats the correct front tracking measurement please? Mk2 172 FF
Need to re-set tracking after new suspention fitting. (prolines+Konis)
yes this is true.. last week i fitted the H&R's and the car got stupidly much negative camber , the toe-in went crazy high. It was almost undrivable !
Had to go and do an emergency setting just to be able to drive it back home, a lot less negative camber (0,7 negative) and as you said ; neutral on the Toe-in/out.
Drives like a dream !
Ps; Izibizi - I'm going for more negative camber though , when it's settled in.
Is neutral toe in/out still good with let's say 1,5 negative camber ??
Cheers Guys
I will set-up accordingly. And let you know the results.
I will also measure Camber at the same time just to see.
I can't view the link for some reason.
But for info after fitting (prolines+Konis) tracking was 6mm out left, 7mm out on the right. All toe in.
Set at +1mm toe out now.
