audacity or even windows sound recorder would do the job, you basically need to re-record i.e. hit play on the minidisc with it plugged into the line in as per above post.
the drm management wont allow transferring of the md to pc it gives you a it will also be in atrac format so the only way is to re record it as described above
ive working sonicstage if you want it the site i used recently to get information seems to have gone
