Trophy Suspension Help
Car  Clio Trophy
Ok simple enough question
Money is very very tight at the moment and dampers are on there way out. are clio 182 cup dampers a direct replacement fit?
Yes they are a direct fit.
Just make sure you 100% get the Cup dampers
so as on west renaults page...
182 cup / cup packed front shocks - 8200681109 - £49.85
direct replacement. nothing else. no need to change springs or anything? any butchering involved?
How long you thinking of keeping the 182 cup dampers on for ?
If you are going to be putting your sachs back on the car thats when i would replace the top mounts with new OE units or solid units
We can referb Trophy Dampers. :)
If nothing is damaged i.e. shaft etc, its not actually too expensive either.
I personally wouldnt, you'll not enjoy the difference between the two, cup dampers are a lot different to sachs
I've got 2 front ones off my 182 @ 42k.
They'll probably end up in the bin so you're welcome to them if you need something to tide you over bud?
10 mins down the road too.
