FredYozzasport said:OMEX didn't like it hence it was stupid
Andy GDI said:raised rev limit only really usfull if you have engine mods that give benefit at higher rpms, cams etc...
seen most cars on the rollers drop off power at 6500-7000 rpm so not much help after that...
piggy backs cant raise it as the dont actually interfear with the ecu, just the signals into it... only making changes to fueling and igntion where required.
charlie b said:Why was the raised rev limit of use to me?
Andy GDI said:if you needed to take it higher for specific reasons... some of which fred has outlined... or to make use of different cams that work better at higher revs etc
FredYozzasport said:no they didn't, hence why Roamer's had a timing pattern on the crank pulley (500), the 600 didn't have it until we had it developed
Lol, i have opened a pandora's boxFinal_Maxim said:Day 32 in the Big Cliosport house and tension is rising.
