Well after Months of having no Rear washer I decided to get to the bottom of the fault.. Had the bumper off and pumps out, one duff pump, success I thought! New pump fitted tested, no washer... So began finding what was stopping it working.. Found the pipe in the arch liner with a hole in it, cut that out fitted new piece of pipe, tested... Nothing! So went into the boot stripped everything out found about 30cm of the pipe packed with dirt, so out came the compressor, blew all the dirt out, refitted the pipe and hey presto I have a rear washer
Then came the simple job of fitting a new pump for the headlight washers, as they didnt work either
Also fitted a new set of spark plugs, to try cure the misfire it has every now and again, seems to have sorted it a little but I think im going to need another 3 inectors, which is rather annoying as I cant really afford much atm...
One last thing the DV is starting to get annoying so Iv taken it off for now, and just blanked the hole up, havnt taken the blanking plate off the turbo yet so im getting a little bit of Chatter from there
going to decided over the weekend wether or not to keep the DV or take it off and pocket £100..
