A3s, S3s, Golfs & TTs with Quattro / 4-Motion aren't AWD iirc, they're FWD with RWD kicking-in when the fronts lose traction.
A4s, A5s, A6s, A8s, Passats, 4x4s with Quattro / 4-Motion are AWD, although I'm not sure if it's 50/50 or 60/40 rear/front power distribution.
A3's, Golf's, S3's, TT's et al, all use the TorSen diff. Not true Quattro. You're right about the diff too, TorSen is not true AWD.
Passat 4-Motion also uses TorSen though, IIRC.
True Quattro's being A4/6/8's as well as the S and RS variants. Later RS variants can distribute 60/40 split, where as earlier models, B5 RS4, for example, use a more crude 50/50 torque split.
Whos that to lol and 11th this month?Agh! Damn you!
You going to Oulton on the 11th?
Has anyone go a QUAIFE ATB DIFFERENTIAL on there clio?? wondering what they are like are they worth it?
Choose against a sadev been told they cant Handel the toque.Thought you were having a 45k Sadev AWD amphibious conversion?
Is it worth getting one do you think??I dont "have" one, but i've driven turbo 182s with and without and it makes a very noticable difference
Well as you know this gearbox i have is slowly going so i think i mightGet one![]()
7000 without new engineThats awesome Ryan congrats on the project! How much have you spend on your clio for all the turbo setup?
so what happened to doing it all for £3k like you told me.lol.7000 without new engine
Eh never said 3k? 5 for all the bits and the rest on oil tools etcso what happened to doing it all for £3k like you told me.lol.
Need to get a day one with someone good at filming an editingCool!! Get more videos of that beast!!!
Its never FWD unless the Haldex Electronic Control Unit disengages the Haldex clutch in the centre coupling as soon as brakes are applied to allow ABS work properly. When performing tight low-speed turns (e.g. parking) the clutch is disengaged by Electronic Control Unit to avoid "wind-up" in transmission.
Under normal operating conditions, the Haldex LSC clutch operates at 5% (divide 5% between front and rear, and 97.5% torque goes to the front, and 2.5% goes to the rear). Under adverse conditions where both front wheels lose traction (hard accel, tight fast turns and quick changes in direction), the Haldex clutch can lock at up to 100% clamping force untill traction is resumed. This means, that since there is no torque tranferred to the front axle, all torque (minus losses) must be transferred to the rear axle in the event of 100% locking. The torque split between left and right wheels is achieved with a conventional open differential. If one side of the driven axle loses grip, then the Electronic Differential Lock (EDL) controls this. EDL brakes a single spinning wheel, therefore torque gets transferred to the opposite wheel via the open differential. On all transverse engine cars with the Haldex Traction LSC four-wheel drive system, the EDL only controls front wheels, and not the rear.
The Haldex Traction system is more reactive than preventative, in that the front axle must lose traction and start to spin before the Haldex operates and sends torque to the rear axle. The Torsen's permanent 'full-time' even torque split under non-slipping conditions makes slipping less likely to start.
The OMP sticker is on top lol.Your rear strut brace is upside down![]()
Amazing nothing wrong with it at all well there is a small boost leak but i cant find where its coming from. Its only losing me 15 bhp lol. Benn worth every penny.How's it running now?
Dunno about that i might do. Dont like them that muchBuckets next!
I got it free and i dint fit it lolGray is right, the brace is fitted wrong, and will do even less like that than they normally do (2 tenths of f**k all)
170amp battery cable from a motor factors or somewhere smilerWhat cable you running the battery with fella?
