What colour would you say? i was thinking about this before but i dont know what colour.Looking good mate.
Spray the brace a different colour though!
Ye and down side of car an earth made in the backCable run through the bulkhead?
The paint thats on it now is all damaged so it 100% needs doing so might look into one of them coloursCheers fella!
Need to crack on with mine
Also, anthracite for the brace imo or gloss black
Amazing nothing wrong with it at all well there is a small boost leak but i cant find where its coming from. Its only losing me 15 bhp lol. Benn worth every penny.
On the rollers you could hear it leaking and the boost dropped alot faster than normal. Fixed it now as far as i know now. It was blowing the air temp sensor outI don't understand this mate, if you've got a boost leak then you are still making the same power as you would without! OK you might have a slight loss as your turbo is working harder to make that boost so getting hotter.
But your actuator is still holding the boost level that you've set it at isnt it? 250bhp at 14psi with a boost leak would still be 250bhp at 14psi without a boost leak?
Only thing is you are overworking your turbo and depending on the size of your leak you will reduce the life of the unit.
Still got standard brake line. Not changed it not had any need toSorted that brake servo line yet with a one way valve?
I didnt have my head in the bay but the guy at rstuning did. Not standard map sensor no. The temp sensor is ok now. Its been fine for 8000 miles so wasnt that badYou could hear the boost leak whilst it was on the rollers? Did you have your head in the engine bay :S
I araldited my temp sensor in on day 1!! Are you still using the std map sensor? glue that fecker in too!!
Its where you can put a waste gate. I just haven't got one there.
Thats been said before mate lol i put waste gate meaning dump valvewaste gate ?????
u actually no what one is and does?
Saw you car yesterdayAll ok now then mate
Smaller mateIs it smaller or bigger?
Mines not anymoreStill mines not leaking boost ha LOL
Running at 16 psi of boost and its doing 291 bhp with 275 ftlb of torque.When did you hear the car lol pm me if you think its better or reply in my turbo thread.
