two topics: spigot rings, and setting up coil over (fitting some in a couple of days)
Car  DCI100
Hi all,
I have to buy a new set of spigot rings for my oz f1's because a garage lost 1. w*****s. any one know the size of oz one bore? so i can get the right ones.
should be fitting vmaxx coilys with in the week. Is it okay to use standard top mounts? not permanent. also what about the bearing etc. do i just set that up the same as they are now.
All advice would be helpful :) thanks
Re: two topics: spigot rings, and setting up coil over (fitting some in a couple of d
Nice one mate :) thanks
Standard top mounts is fine. Even permanently.
Put them on the coilover strut exactly the same way they came off the standard strut.
Top man :) just what I needed. I intend to go to solid eventually for the camber adjustment only problem is it makes for lesser ride quality. But who cares :p
