Typical Ignition map
Anyone got a typical Ignition map for a f4r/f7r?
I've been given this to start me off with mapping but its terrible imo.
what ECU is that for?
Looks reasonable (if not a bit retarded) above the 26% line, but the bottom 4 lines are nonsense
Megasquirt based by the looks of it.
Make sure you check with a strobe light that zero degrees is actually zero degrees.
The two rows of noughts and the stuff just above on the left is obviously wrong but the rest looks reasonable as a basemap.
Cool will do. They say to check at 10degrees but that requires buying an adjustable strobe light.
Will zero degrees be fine to check?
