J Jay_Kay Car Clio mk1 Jan 27, 2014 #1 Anyone got a typical Ignition map for a f4r/f7r? I've been given this to start me off with mapping but its terrible imo.
D Dan519 Car DON'T SEND ME PM'S!! Jan 27, 2014 #2 what ECU is that for? Looks reasonable (if not a bit retarded) above the 26% line, but the bottom 4 lines are nonsense
C Chip-mk1 Car 182/RS2/ Turbo/Mk1 Jan 27, 2014 #3 Megasquirt based by the looks of it. Make sure you check with a strobe light that zero degrees is actually zero degrees. The two rows of noughts and the stuff just above on the left is obviously wrong but the rest looks reasonable as a basemap.
J Jay_Kay Car Clio mk1 Jan 27, 2014 #4 Chip-mk1 said: Megasquirt based by the looks of it. Make sure you check with a strobe light that zero degrees is actually zero degrees. The two rows of noughts and the stuff just above on the left is obviously wrong but the rest looks reasonable as a basemap. Click to expand... Cool will do. They say to check at 10degrees but that requires buying an adjustable strobe light. Will zero degrees be fine to check?
