Clio 182 cup
Hey guys. A few weeks ago i posted an issue to do with a new brake disc fitted becoming really rusty after fitting new rear discs and pads. Anyway half the brake disc on the rear passenger side is still rusy as though the brake pad is not connecting with the disc. Have tried to bleed the caliper in case this is the issue using one of those one man bleeding kits but nothing is coming out, no air, no fluid. Tested the kit on the other rear caliper as i thought i was being a t**t and not doing it right. Got fluid out the other caliper fine, but the rear passenger caliper, cannot get air or fluid out. I've refitted the new pads in case that is the issue but i don't know what else to try. Do it be an issue with the piston?
