Uprated valves on a rebuild
Car  Ph1
Would it be stupid not to uprate the valves when doing a rebuild or is uprated only really required for ragging it on the track?
I don't want to lash out over 300 notes if not really required :)
Is it worth the risk if one drops???
Your money your choice mate, but as we know they do seem to drop a valve. My head is coming off over the winter and i will be buying Supertec`s
I know its quite expensive but not as expensive as a smashed up engine.
Is it just a choice of the Supertech ones?
Also i have the stock valves cut 3 angles with headwork on my old engine which worked well. Worth getting the new valves cut ?
Nearly forgot, should i fit new valve springs as well or will the old ones be fine?
Danny @ 519 has a different manufacturer of 'one piece' valves.
The Supertech's can be had for £300 on the nose if you know the right people..... http://www.rolandalsop.com
