Urgent Clio 16v dash wiring help needed!!
Car  Bmw M4 & Clio 16v
Guys,
I am trying to wire in a digital dash onto my clio 16v. 1993 K reg
I have basically tracked every wire I need and know which one does what, but now have a couple of issues?
Indicators.
The L and R indicators work but they are flashing very quickly (like there is a ground off, or bulb blown) but I have check and everything is working fine.
The L indicator is a brown wire that connects to the dash display and the R is an orange one.
I have a spare brown wire that does not appear to have a home - but if you connect this spare wire to either the brown or the orange wire then the indicators on that side flash at the correct speed?
Any one understand this?
I have tested this wire with a meter and it is pulsing as to cause the light to flash? Where does it go?
Hazards
These work fine and flash at the correct speed?
Fuel sender
I have tracked this wire and it seems to be a green wire with a white stripe in it. I have connected this to the fuel guage and don’t get a reading. I know it worked from my standard dials.
Any idea if this is the right wire?
HELP GUYS ITS GETTING URGENT NOW AS NEED CAR ON THE ROAD!
