172 turbo
hi bassically started the mod for removing air con and putting in standard cup set up and now ive removed ac pump and old alternator, and theres several different brackets/casting that need removal, now im sure i need to remove this one and if so my last right basically just covering the powersteering pump is a bracket that bolts to the block and from the side where u have to remove the pulley to take out bolts, and last but not least on this bracket i noticed at the v bottom there a bolt, how ever the bolt has part of the pump in the way meanig i need a special tool/socket spanner can people give me help to what i can use. for the last 2 hours i have been grinding cutting sockets and spanners got close with spanner but not enough leverage what have u used i need this last bracket off to fstart asem cheerS?
