urgent help needed engine bay in bits tooling powersteering bracket?!
  172 turbo
hi bassically started the mod for removing air con and putting in standard cup set up and now ive removed ac pump and old alternator, and theres several different brackets/casting that need removal, now im sure i need to remove this one and if so my last right basically just covering the powersteering pump is a bracket that bolts to the block and from the side where u have to remove the pulley to take out bolts, and last but not least on this bracket i noticed at the v bottom there a bolt, how ever the bolt has part of the pump in the way meanig i need a special tool/socket spanner can people give me help to what i can use. for the last 2 hours i have been grinding cutting sockets and spanners got close with spanner but not enough leverage what have u used i need this last bracket off to fstart asem cheerS?
Cro
  Meg'd r27
Hard to get what you mean from that huuuuuuuuuge sentence lol but I think what you are talking about needs you to remove the pulley from the powersteering pump. Then you'll have room to get the bolt, remove the pump then remove the brackets.
No special tools needed, all bracketry needs to go, take the alternator and pump out before all brackets and jobs a good'un
  172 turbo
hang on yeah iv removed the pulley on the psp right , and that gave me acess to the bolts on the side, but this bolt is underneath and the bottom of the pump comes over it a bit meaning i have to use a spanner of some sort but cant get enough leverage as cramped u know what i mean ideas what tool and how u do it ?
  172 turbo
hang on u serious well how do i remove it as i can not see any bolts for it only the bolt that im havving trouble with in the bracket no 2 wont psf piss ouit everywhere and become empty cheers hwo do i do this need to have it all out tonight .???
Cro
  Meg'd r27
No leave the pump connected, its 3 bolts 2 top 1 bottom as far as I remember. 2 behind pulley(which needs to come off) 1 on the right as you look at it. I'm also guessing you dont know that the pump needs some work to fit the cup brackets.
Either the cup high pressure line = £200 or you need to get custom.
Lol its not happening tonight by the sounds of it
  172 turbo
ive herd you can just bend it , also k tec would not lie when i spoke to sean personaly said direct fitment, ive got all brackets off not and pumps hanging with all piped connected shud have a go disconecting a few and bending them slightly one bloke did it before was fine ??
