Urgent help required!!
  Clio 200
Just changed rear pads on my 2010 Clio 200. Put in Oem Brembos no problem at all. Only issue now is that the pedal won't firm up at all. You can clearly see the piston on both calipers coming out but then going back in and leaving slack in the caliper which is causing it to rock slightly. We've also bled them which hasn't solved it.
They were perfectly fine on the way over here.
Any ideas?? Ta.
  Clio 200
Yeah they are. All sorted now thankfully. We had to wind the calipers out a touch so they were very tight. Taken the car for a quick spanking and they seem all fine now.....touchwood!
