Fitted a V6 airbox earlier with ITG filter. used original elbow, no caf fitted yet until I get my samco elbow. When I start the car up the engine management light stays on, anyone know why its coming up?
The vacumm pipe that connects to the acoustic vavle? There is nothing on the airbox assembly that you could remove that would bring a warning light on. Chances are you've knocked something during fitting it as its such a tight fit. Haven't has any troubles with mine
my idle is fine, idles at about 1000 rpm. I removed the airbox and everything seems fine. Looks like i'll have to buy a code reader and see what the fault is.
