V6 Airbox fitted, engine light is on. Help?
  Roadster Coupe
Fitted a V6 airbox earlier with ITG filter. used original elbow, no caf fitted yet until I get my samco elbow. When I start the car up the engine management light stays on, anyone know why its coming up?
  Roadster Coupe
The original caf with accoustic valve is still attached. but doubt this would make a difference.
  Golf GT & A4 Avant
The vacumm pipe that connects to the acoustic vavle? There is nothing on the airbox assembly that you could remove that would bring a warning light on. Chances are you've knocked something during fitting it as its such a tight fit. Haven't has any troubles with mine
  Roadster Coupe
my idle is fine, idles at about 1000 rpm. I removed the airbox and everything seems fine. Looks like i'll have to buy a code reader and see what the fault is.
  Roadster Coupe
it turned it self off after about 60 miles of driving today, bit strange. oh well all sorted now
