It seals internally mate on the air filter element.
Thanks !
All fitted now, that's how I did it
I have drilled small holes in upper part of the box, in the locations where original clips supposed to be attached. Then I have run zip ties through drilled holes, and the holes for the clips in the lower part. Maybe it is not completely OEM, but I guess it is ok compared to running zip ties across whole box !
with ties being black it is not so apparent in the engine bay. Also the integrity of the box is intact, in case I will come across original clips at some point (which I highly doubt
One last question - my airbox came with original CAF from Espace, which has quite strange design. It is 100mm or so at the exit from the airbox, then i narrows down across it's lenght to approx. 50mm diameter at the end, similar to shape of cone. Any specific reason why it look like this, compared to fixed diameter at whole lenght ? Should I fit or rather buy DIY duct ?
Cheers !
