my car had them when i bought it, it was running standard pads at the time, then i changed for greenstuff and it was much much better
however, im getting a vibration through the brake pedal and i can see that the brake discs are wearing very unevenly on the surface so that may be the cause
can the v6 discs and calipers both be made to work in conjuction with one another on the 172, im guessing a bracket will need to be made??
im after discs that at at least 300mm so they dont look small behind my 17'' superleggra's, i dont mind swaying away from the wp pro stuff if needs be!
