V6 rear caliper
Hi guys
Looking to change the pads on the rear, (done the fronts) Any special tools needed for this job to retract the piston to get the new thicker pads on? Or is it just a case of loosening the handbrake cable. Any tips on retracting the piston would be appreciated
Steve
MRBILLYUK
  FF Jeden Osiem Dwa
Are they different to normal calipers ? You normally just wind the piston back into the caliper clockwise with a piece of flat bar , or something similar that will fit in the groove . Make sure you leave the handbrake off so leave it in gear and put some bricks under the tyres to stop it from rolling .
MrBillyUK !
® Andy
  Illiad V6 255
As far as I know they're the calipers of the front of a Citroen of all places!
You'd probably be best off asking on v6clio.net.
