valver- engine mounts
  clio 16v
is the bit next to the power steering resevoir an egine mount?? mine looks very perished, and i have noticed lot more visable movement in this part of my engine than normal- would this be a mount problem?
alos it really stuggled to idel today when i 1st started it, it was in blinding sunshine! so it wasnt cold, but after a min or so warming up it sounded normal, any ideas what the cause of this could be??
Yep, that mount is about £80/90 I think for everything from Renault. (It is worth going genuine)
  Valver
I don't think that one is too much of a challenge, I did the one on my 1.4RT just had to support the engine on a jack while you take it off (which I forgot to do till the last bolt and wandered why it wasn't coming off) but not sure on valvers?
77 00 818 994 Engine Mount - Top £69.92 +vat
77 00 806 577 Engine Mount - Gearbox £25 +vat
77 00 849 715 Engine Mount - DogBone £27.25 +vat
You can also get an uprated dogbone mount from Hillpower for about £50. I've had all mine done and it makes a massive difference!
Good man! :D
Don't forget to ask if you can get a little bit off as they are expensive parts and they have about a 20% profit margin on anything with a code starting with a '7' I believe... :evil:
Never had any problems using a non-renault top mount. Gearbox mount needs to be renault tho iirc cos i couldn't find one in the factors.
Top mount from eurocarparts is £30.
