Valver gear stick - should it move a lot?
  MK1 Clio 16v
Ever since i've owned my valver it has a strange problem where the gear stick moves backwards and forwards a lot, more than any other car i've been in. If i'm in first gear and i'm rolling, if i take my foot off the accelerator the gear stick violently moves forwards, and if i tap the accelerator it will violently rock backwards and forwards, i'd say it moves about an inch or so each way. Should this happen?
It happens in any gear but obviously not as violently in higher gears.
Martin_172
all clios ive been in move but mine is more violent than others and feels a bit rough when changing gears, turned out to be a fuked gearbox mount
  MK1 Clio 16v
I had a new clutch fitted recently as well as head gasket and full service and he checked all the engine mounts etc, so i imagine he would have spotted if the gearbox mount was screwed?
  1996 Valver
No, it is definitly the g-box mount, known as a 'dog-bone mount'
http://www.bbperformancetuning.co.uk/products/product.asp?id=14980
mas
  MK7 GTD & Mini GP
same with mine kiz, knew it was the dogbones, need to get that sorted too!
  S2000
It'll almost certainly be the dogbone mount as shown above. You can get one for about £15 from a motor factors and a garage shouldn't charge much at all to change as it's a 5-10minute job at most with a lift.
  MK1 Clio 16v
Yeah i've done that before, if you boot it, it can hurt your wrist sometimes...
Will it be obvious if the old dog bone mount is worn?
  182
Yup mark 1 syndrome lol plus i would say the mounts gone. Sorted mine out but still had a little movement in the end
  MK1 Clio 16v
I'd expect a little feedback in any french car to be honest, it's just a bit too violent at the moment so i might just get it sorted before i damage my wrist ;)
