20VT Clio & 9-5 HOT
Been having problems with a dodgy idle for months now. It also cuts out when coming to junctions occasionally untill it is fully warmed.
Anyway iv got a couple of other things to try but filmed it today, as i had to start the car up anyway, seen as its sat on teh drive not doing much.
http://homepages.nildram.co.uk/~cadams/videos/myvids/engine/engine1.MPGPart 1 - 6.1mb
http://homepages.nildram.co.uk/~cadams/videos/myvids/engine/engine2.MPGPart 2 - 4.9mb
Anything obvious that could be causing this? Bearing in mind iv changed:
ISVC
Throttle body
potentiometer
speedo cable/road speed sensor
lambda
change of ECU on the way, as im running a 19 16v one and i know someone on here was having problems and the change of ECU solved it! also coolant tempt sensor and probably map sensor as well!
