20VT Clio & 9-5 HOT
righto, ages back my car was cutting out at junctions, and idling quite low! i cleaned ISCV, changed speedo cable, and same problem. Me and Paul16v then adjusted the potentiomenter (as it sorted his out), and the idle went mad, so put it back as best we could! Then changed the ISCV and it was off and on for a while.
anyway, its still doing it! when its completely warm its fine, and if i blip the throttle just before the revs drop too low it doesnt stall! underfuelling?
Also the car refused to pop on demand as it usually does. cant get it to pop at all! when the problem was intermittant, it used to pop all the time when it was fine, but never would when it was playing up!
now i reckon its either the potentiometer that needs adjusting spot on by Renault, or the lambda sensor? anyone know for definate, as im pretty broke, and dont wanna try one and it not fix it! then have to fork out for the other!
Cheers for any advice people!!!
