valver wheel bolts (only 3 of them)
Car  Renault Clio 1.8 16v
one of my wheel bolts in my rear hub is spinning tryed tapping it out but its just to fucked, the 3 are ded tight, finkin of goin down cornwall in it from notts?? lol
Should be allright driving with 3 in the rear, but its not really advisable, although i drove from northwales to portsmouth with 3 in the rears.
i see, i have 19mm spacers on aswell, did you take it easy? was it both back wheels? mine is only 1.
Ah if you have spacers, i personally wouldnt risk it. there is allready more strain on the bolts having the spacers.
probly guna take em off jus cant find all my old wheels bolts, did it drive there fine with onli 3 then?
Get it checked ASAP
You should have longer wheel bolts with the spacers anyhow?
Dont risk driving with anythign like that, will be very dangerous.
it wont f**k the bearing up as much if i take the spacers off, 3 of them are very tight 1 just catches the thread but it gets abit tighter wen i drive it, too much money and time to change a whole hub b4 next satday too lol.
I've heard of a few people who have driven with just three bolts on the rears for 1000's of miles. If you can avoid it then I wouldn't drive with just three though, especially as you have the spacers. Pop down to renault/halford or somewhere in the morning and get yourself another wheel bolt.
EDIT: Wasn't thinking when I said to get another bolt, I read the post earlier and had forgotten it was just spinning in the hub.
i am taking my spacers off so it will be tight up against the hub, its onli the 1 rear wheel bolt that its spinining in, gets a little bit tight like i said, seems a healthy risk to take so far.
