Could someone kindly point out to me the location of the washer jet fuse on the ph1 172, checked the side of the dash but it's not there any help appreciated greatly!
Mine was the pump too, There is a guide but I think it might be for the ph2 becouse it has you removing wipers etc. I just pulled back the plastic trim nr the passenger side wiper and the motor pulled out (watch out for the seal) then disconnect the plug and maybe check to see if it is getting power.
As your looking at the fuse board, the smaller fuses second row up from the bottom, on the far left. Photobucket wont let me upload for some reason. If your rear wiper and reverse lights are working its not the fuse.
