Washer jet pobs help please
Els
Car  Inferno 182 Cup
For some RANDOM reason the driver side washer jet has stopped working today.
Ive pulled off the pipe that feeds water to it and it it clear of any blockages. when it aint connected to the washer jet water comes through fine.
Ive put a pin in the holes of the jet to try and clear any potential blockages but to no avail. Any ideas anyone?
Whats the easiest way of taking out the jet (without braking it) so i can have a look at it? and blow some air through it.
Help MUCH APPRECIATED!!!
if water is getting to the jet, but not through it, then the problem will be a blocked jet.
one option is to keep the pipe on the jet, disconnect it further back and blow into it hard, another way would be to disconnect the pipe from the jet and put it against the front of the jet, and operate the jets to try to clear them 'backwards'
i have a similar problem. mine makes all he noise but no water comes through, not even to the rear jet. what could this be?
