Washer Nozzles
Car  Corsa SXI 1.7 DTI
Anyone know how i cant take these off? need some work doing to them and just wondered how hard it is to remove them?? had a quick search but couldnt find any guide on here so far.
Maxx
on the headlights or bonnet? if on the bonnent ten pull the pips off and push the nossels through. might need a slight bit of force. hope that helps
did you get this sorted? i could do with a new one and would like to know how easy it was to do
Can you reach them from inside the bonnet? iirc there is no direct access to them...
yeah you can. they are a bit of a pain as they have 4 little plastic fin type things that stick out to stop them coming loose. you have to try to push them all in towards the washer at the same time to get it to pop out.
