A wastegate is in the exhaust, and bypasses the turbine to control the boost.
A dumpvalve is in the inlet and make a moo noise when you let off the throttle
yer im familuar with dump valves but i love the sound of waste gates and with me a few months away from buying focus st i want a wastegate! how easy are they to fit? as i no the dumpvalves are a doddle
You literally just remove the DV and block up all the pipes, you'll also need an open filter for full effect!
Loved the sound my Punto used to make!
Without one you get a pressure wave that bounces off the throttle butterfly and reverses up the boost pipes and rushes back through the compressor side of the turbo. This makes the "chatter noise" (and btw it's nothing to do with the wastegate).
Turbos must have wastegates so that the amount of boost pressure delivered can be controlled. If the wastegate is open it allows exhaust gas to bypass the turbine (hot side of the turbo) thus reducing the turbo speed.
There are internal wastegates (built into turbo with an external actuator) and external wastegates (which often give better boost control).
There are pretty nasty consequences for having a wastegate that cannot handle the boost.
A dump valve releases excess pressure in the boost pipes when you back off the throttle. Without one you get a pressure wave that bounces off the throttle butterfly and reverses up the boost pipes and rushes back through the compressor side of the turbo. This makes the "chatter noise" (and btw it's nothing to do with the wastegate).
Two basic types of DV are atmospheric and recirculating. Atmospheric dumps to atmosphere (classic tsssh noise) recirc will dump into the inlet side of the compressor (this is what OEM turbo engines do to reduce noise).
^^ TruthWastegates never really make any noise. The "chatter" thing you can hear happens as a result of having no DV.
