Hi guys,
i have a 1996 Renault Clio Versaille 1.2 and im having a water leak problem.
Last night as i drove home the warning light came on and the pretty much stalled out over heating. managed to pull over and let it cool down put some water i had in the car in it and nurse the car home. This morning i filled up the tank and checked under the car only to see that a steady stream of water was leaking out under the car. it was coming over the top of the cambelt.
any ideas what i can do to fix it? i need to use the car, im thinking its probably the water pump, however would you recommend me throwing some rad weld down the pipes just in case?
need some advice on this one folks!
thanks
Pete
thanks
Pete
