water on the floor
Car  Megane 225+
Went to wash my screen yesterday - no water in the windscreen washer bottle - completely empty - strange i thinks.
Filled it up tonight, went back out with my second jug full, noticed a wet patch on the floor, thought I'm sure i didnt spill that much!
Taking closer look - waters leaking onto the tyre from above - through the inner lining in the arch (steady flow)
So filled it up
Tested and it does squirt onto the screen
One hour later no water left!
Anyone had the same prob?
Could it be a loose connection at the bottom, the leak must be form the bottom as its completely empty
looks like a b**ch to remove, any advice appreciated.
Just had the same problem with mine - water bottle is leaking. Can't even get to it to have a look where its leaking :(
is there anything leaking from the headlight washers? they're prone to leaking too, if not just the water bottle prob.
