I have to take out this relay before I can do the compressio test. Othervise the injectors will pump fuel into the cylinder while testing...Worry about that after you have done the compression tests.
Just unclip the injectors.I have to take out this relay before I can do the compressio test. Othervise the injectors will pump fuel into the cylinder while testing...
Won’t the pump then still be supplying fuel and pressurize the system?Just unclip the injectors.
A little fuel vapour, nor engine temperature is of any concern.I have to take out this relay before I can do the compressio test. Othervise the injectors will pump fuel into the cylinder while testing...
unplug injectors and make sure wot.
yup, throttle is off so no need to worry about that. i unplug injectors though. warm engine and crank a good few times until the needle just about stops moving.
those figures are bloody low but close so i'd be more tempted to say the low reading is down to the tester.
To stop fuel entering the cylinders causing a false reading?
It was you that advised me to do so as im a bit thick :smiley:
Did you remove all the spark plugs?The results of the compression test are
150-150-145-155
All at onceDid you remove all the spark plugs?
Or one at a time?
Have you done a wet test afterwards?The results of the compression test are
150-150-145-155
Doing the wet test right nowHave you done a wet test afterwards?
The figures are fairly even, if a little low. but that may be a characteristic of the gauge.
Smear a little grease on the o ring to reduce friction when tightening the connecting hose, as I`ve noticed some don`t tighten down that well and just spin without sealing properly.
If the wet tests shoot up to 180 psi, you have a problem with the bores/rings.
Repeat a dry test with the sealing grease first, in case that is the cause of the low reading, then do the wet tests.Doing the wet test right now
Noticed that myself, I’ll try with grease, thanks
I’m not an expert, but can’t this be because some rings are more worn that others?Some odd readings here, the one that was lower is now higher on some tests.
But surely the one with the lower reading would still read lower than the other no matter what test you did?I’m not an expert, but can’t this be because some rings are more worn that others?
Seems right...But surely the one with the lower reading would still read lower than the other no matter what test you did?
Im no expert either but isnt that just logic?
Maybe, i think it has to be warm for a proper reading mate.Seems right...
Well the engine wasn’t really at operating temperature for the last 2 tests, could that be a reason?
This.I’m not an expert, but can’t this be because some rings are more worn that others?
Thanks, good to knowThis.
I still have concerns regarding the sealing of the test gauge.
From the 2nd set of dry readings I would conclude that the engine is not a basket case, though a little tired.
You have readings in the 220`s as you have 20cc of incompressible oil occupying 50cc of the combustion chamber.
Please repeat a compression test in the morning, without adding more oil.
The oil will leak past the cylinders with worn rings overnight, revealing which are worn.
On a brighter note, the valve seating is good, and I suspect the bores are good enough not to be the cause of your original concerns.
About as much difference as the current atmospheric pressure..Thanks, good to know :smile:
So the lower temperature didn’t mess up the readings?
The brand is Silverline.What brand of gauge are you using?
If it's a Gunson, I would take the readings with a pinch of salt.
Have you retested today?The brand is Silverline.
Bought it on amazon
Not yet, haven’t had time todayHave you retested today?
I would not worry about warming it up.Not yet, haven’t had time today
And I’m not sure if i will be able to warm it up before the test, no space in the driveway...
That’s what I wasn’t sure aboutI would not worry about warming it up.
In fact it would make any readings useless.
What we are trying to establish is which cylinders have retained the oil overnight and not leaked away.
I hope you have not started it since you did the wet test.?
Good, if you get the chance.That’s what I wasn’t sure about
Nope, hasn’t been started since the last test
I did the test twice now and here are the results:
180-185-190-200
170-180-175-195
I suspected that the engine wasn’t in top form anymore, but thanks for the confirmation that I don’t have to scrap it yet.Thanks, that`s more or less what I expected.
I think it`s safe to say that you don`t need to tear the engine down, though it`s not tip top.
These readings are left to right, gearbox end to front of the engine, as was the original photo of the plugs?
For the moment, put your old plugs back in, crank the engine over on the starter motor to expel any remaining oil.
Give the dizzy arm & cap a thorough inspection, including the carbon brush and clean up any evidence of arcing with some emery cloth.
Also measure the in line resistances of the HT leads.
I`m hoping that the valve guide seals are good.
Yes, still the same order as in the photo.
Resistance is 2300 ohm.
