Wet sparkplugs
  Renault Clio 1.8 16v
So I changed the sparkplugs on my 1.8 16v and notived that they are a little wet, but I don’t know if this is too much or if it’s normal for the age.
I just want to know if the piston rings are bad or something like that or if the engine is fine.
I have never seen blue smoke from the exhaust btw.
That was changed recently, so I doubt it’s broken again.
I was talking about the part of the plug that goes into the cylinder (don’t know how its called exactly)
  renault clio 1.4 16v
looks like 2 cylinders are burning richer, could be injector problem, could be compression problem, easy enough to check for both, can swap injectors around and see if the wetter and blacker plugs follow the injector, and compression test will show if there are bad cylinders...
Coops Mk1
  Lots of Scrap...
check the rocker gasket again, they are a pain to get right and that above is typical symptom of oil leak from the rocker into the plug wells
If I remove the rocker/cam cover to check the gasket, can I just move it into place and retighten the cover or do I have to apply something to the gasket?
Never replaced gaskets by myself
JamesBryan
You can't just remove the cover i'm affraid.
You'd need to lock off the cams and remove the belt and pulleys.
Got it, but don’t know when I will have time to do it :/
If I want to take the only the cover of to repaint it for example, would I have to go through the same process with the belt and cams?
JamesBryan
Paint it in place as it is.
The oil leak isn't a major thing really. My 182 has been doing it for about 2 years, i'm just waiting until the next cambelt change.
Oh ok, so you say just mask-off the engine bay and then spray it in there if I understood correct?
This is a 1.8 16v not a Clio sport so you don't have to touch the cams, belt, pulleys, there's nothing to be afraid about. Its just a case of removing the valve cover and replacing the rubber gasket.
Coops Mk1
  Lots of Scrap...
1.8 16v F7P engine you can remove the cam cover no problem, the cams have seperate carriers
Coops Mk1
  Lots of Scrap...
I would also suggest binning off those awful 4 electrode plugs aswell and just getting some bcr8es ngk single electrode ones
Thanks for the clear answer
Replaced them the same day I took that photo :p
When I take the cam cover off, do I need some sort of grease for the gasket or can I just retighten the cover with the gasket placed correctly?
Coops Mk1
  Lots of Scrap...
Like this, but 8`s are too cold for this engine.
6`s would be tops.
sorry yes, I was still thinking of the ones I use for the turbo lump, its 6 you want @Booty
ideally you will need a new gasket as its a crush type so theoretically one use only. I've always just tended to loose the gasket completely and use a thin smear of tiger seal, thin being the operative word as the last thing you want is squidged out excess dropping onto the cams etc.
R3k1355
Yes, I did, why?
I didn’t do I myself
Just it appears to be leaking, which isn't great for a new gasket.
Have you got receipts, or did you get it done in your ownership mate?
Yes, in my ownership, about 2 months ago
One explanation is the gasket was replaced, but the plugs/plug holes were already full of oil and you're just seeing the mess left behind from the previous leaking gasket.
  PH2 172
The plug on the left of the picture (No1 gearbox end) is not firing correctly, and No3 does not look much better.
Talk about gaskets & oil on the threads is irrelevant.
To check the condition of the piston rings, start with a dry compression test, followed by a wet compression test. ( A measured 20cc of oil squirted down the bore from a syringe )
If cylinders 1 & 3 improve significantly over 2 & 4, there is a problem with the rings.
If there is not a significant improvement with the wet test, but the compressions are inconsistent between cylinders, then you are looking at a valve sealing problem.
Compressions should read 180 psi or 13 bar ish, but all being the same is more important, as I doubt the gauge will have a calibration certificate.
You need to do this before looking elsewhere.
As you have confirmed the plugs are pictured in order, this has eliminated a coil pack problem, thank you.
I will ask what number is on these NGK plugs, as they are not the correct type?
Thank you for the detailed explanation, I will definalety do a compression test as soon as possible.
Old plugs: BKR6EQUP
New plugs: BKR6EKUB
  PH2 172
Old plugs: BKR6EQUP
New plugs: BKR6EKUB
The original 1.8 16v plug was BPR6EK.
b= 14MM thread
p= extended tip
r=5k resistor
6=heat rating
e=long reach thread
k=dual electrode
from the top of my head.
  PH2 172
Old plugs: BKR6EQUP
New plugs: BKR6EKUB
If you bang in a 4 electrode plug into a system powered for a 2 electrode, you end up with 4 weak sparks, rather than 2 good ones.
But that`s by the by.
Crack on with the compression tests.
Need help once again.
I just received the compression tester I ordered, but I can’t figure out which relay is for the fuel pump. Google didn’t help much either...
  RB Clio 182
I think its the little black square in the fuse box under the bonnet, theres 3 black square ones and i think its the middle one.
  PH2 172
Worry about that after you have done the compression tests.
If they are all good, I`d take a good look at the distributor cap, arm & leads next.
