What could I use?
  Renault Clio
The rubber near the top of the car has worn but part of it is still hanging on. On top of that on the inside there's a strip that seperates the front window and the driver's window on the right of the car, the top of the strip is loose. I've tried super glue with both of these problems but it failed majorly. Is there anything stronger I could use that would definitely sort it out and keep it stuck in place?
Pics...
my.php
  Clio 182 Cup
the bit on the window lol i have that same problem when i had my new windscreen fitted ive used a double sided sticker the ones u use to hold number plates on with
I would try heavy duty velcro from halfords for the interior A pillar, You or the next person might need to get it off if they want to get the dash out.
Maybe alraldite for the windscreen plastic, Although i would be carefull as its a b**ch to get off and i wouldnt want any on the paint.
Or maybe silicone, You would need to tape it in place until it drys, And the silicone is easily removable if it does'nt work.
