What do i need to fit 197 4pots under a 15 inch wheel (williams/2118)
ive done searches and found a fair amount of information but i'd like to see it all in one place, preferably by someone who has done it!
I have the calipers but thats all, nothing else and no machining done yet, thanks in advance!
280mm brackets
Calipers machined 5mm off of mounting face
May need some material removed from the top and bottom of Calliper where it comes close to the wheel
And a spacer depending on which wheel you use, et depending
Exactly as @scooby-93 has said. You'll need to machine the caliper edges off to get it under the Willys wheels. I use 15mm spacers.
You'll also need new lines. I got braided HEL ones from Chris Powell.
Here are mine;
