What exhaust clamp?
fil_b
  172 FF and Fabia VRS
Hi there
i need to replace my clamps but which ones?
standard universal u clamp or the Milakor style clamp?
thanks
​phil
DaveDreads
Well the other day I bought a 2 1/2" u clamp for my 2 1/2" exhaust and it's was too small,
guess I need 2 3/4" or something.
fil_b
well I have been and got the mikalor style clamp and it fits like a glove.
went for the smaller and bigger size as I was unsure which I needed and didn't want to be stuck with the car in the air and no way to secure the exhaust pipe.
bigger one fitted and the secured the exhaust perfectly. need another for the cat join now.
defo recommend these clamps if you have blowing issues so much easier to fit and tighten up.
I recommended them over the u bolts tbh, I will buy these in future
fil_b
I ordered 1 59-63mm and 1 63-68mm.
it was not till I was under the car I realised the smaller is not use because the expand the pipe to join them. but I have a 2.5" ktec system.
check whats yours is before ordering
fil_b
measure the join
edit
2.25 inches converts to 57.15mm
but
you need to look at where they join as its thicker
M.C..
I have used Mikalor clamps for years on my exhaust and they are much better than the cheap crap U clamps, they do not crimp the sleeve of the exhaust so it is easier to get off when you need to, worth spending the extra few quid.
fil_b
ordered my 2nd clamp today
just an update you need to measure the bulge in the pipe.
63mm - 68mm is what I ordered
