What gearboxs would fit on?
Car  learning in corsa 1.3tb
Just wanted to know which gearboxs would fit on a mk1 valver f7p/f7r engine. Looking to change to a gearbox with closer ratios. Any ideas????
iirc the valver uses a jb3 box and the williams a jb5?
in theory a 1.2 16v jb1 box should fit on but will it take the power/torque? theres a reason the 1.4/1.6 16v use a jb3 and not a jb1 after all!
okay the reason that i ask is because i was told by a breakers yard that only a valver box would fit onto a valver engine due to the bell housing being a certain shape. just wondered if this was the case
You can fit any JB/JC series box to it. The bellhousing pattern is the same.
Valver uses a JB3 box, Williams a JC5.
Which engine you looking to use? F7P or F7R? The valver box is closer ratio iirc but its torque rating is lower.
would be using the 1.8 valver engine. Okay but would any of the other boxs in the range jb/jc give better ratios or would it be best to stick with the jb3 box?
valver boxes are largely the same as the williams boxes. The williams are stronger and have a longer 5th (maybe a longer 4th too). This is due to the F7R williams being longer stroked (giving the extra displacement) so it's not as revvy.
williams boxes are regarded as the better longer lasting, stronger box.
You may be able to fit a 1.2 box. But I'd only do that if you could find them dead cheap and you could fit them yourself in under a day. Then treat them as disposable boxes becuase they are not going to last all that long. especially if you have a good F7P.
Stick with the valver box IMO. Cheap, quite close, and strong enough
The reason that i ask is that the car is pushing almost 200bhp and i was looking for a box with closer ratio's to give better performance.
