What have you done to your car today ???
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
tried to suss why the EML came on 3 mins after receiving the MOT refusal paperwork :/
Because French car!
My 172 did this for a week when the MIL just came on and off at random. Turned out to be the post CAT lamda so took it for a harsh of pure abuse around the back roads and now works perfectly.
Sometimes they just don't like being stood.
Because French car!
So 'Italian tune-ups' work then!
  172 Cup
Noticed my passenger side front tire is shamefully bald, its worn evenly but is more noticeably worn than the drivers side, the drivers side still being legal.
2x Uniroyal RS2's ordered @ £66 each delivered, hoping it helps the car feel more planted. Ive read on here that unevenly worn fronts can cause wandering at speed. Getting 2 birds stoned at the same time would be nice.
danward
  M135i
Silvervisions fitted at the rear.
Metal throttle pedal fitted.
Metal footrest plate fitted.
iPod adapter installed for JVC headunit.
Finished fitting the vibratechnics gearbox mount, Refitted the battery that had been on charge. Tried to fire it up but it cranked but wouldn't fire. Plugged the RS tuner in and had about 6 df009 codes - actuator relay fault. Having second thoughts about making it my daily now lol.
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Easy one... Most likely corrosion on the main control relay terminals, faulty main control relay or corrosion to the 30A/15A fuses in the bay stopping power flowing properly.
Yeah I fixed it, sprayed a load of WD around there, looks like someone has been there before tho as there is solder on the bottom of one of the wires out of the top relay and is loose so have to push it in after the relay has been put in. F00king shed.
Next one to find is why the stereo or clock display things don't work!
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Mine did that to and only came on when you actually turned the stereo on. Turned out to be a blown fuse but the previous owner decided to remove the dash top, took a wire from the back of the stereo and ran it to the clock.
That was so much easier than replacing a 10A fuse in the passenger side of the dash.
  Clio 172
Fitted new wheels to my car
  extreme flamer
Broke the err... Brakes.
How did you break your brakes? Ive broke mines twice in the last 2 weeks, hopefully for the last time on wednesday!
Wasn't today but this weekend I've washed, waxed, dressed the plastics, tyres ,etc. for the last time till spring, cleaned the interior and pretty much changed it back from a workvan to a clean car then fitted clean number plates instead of advertising a dodgy dealer.
Ray Gin
  Tesla & Impreza
MOT on Friday so getting headlights aligned and an Escort CAT welded into my spare Decat pipe, lol.
BlackGoldMatt
  Tesla Model Y Perf
yesterday i had a day off work, coilovers fitted, new front ball joints fitted and then to the garage to have 4 new tryes fitted.
Weekend i shall be getting the alignment done.
  CursedTitanium 182FF
Fitted my Eibach rears, was going to do the fronts along with the bottom arms, but ran out of daylight due to a seized nut & lack of proper tools for the job.
  big boost cup
emptied all of the water out that has collected on the floor and put a car cover on it. massively exciting i know
  Astra (H) VXR
Bought 60 new cr1220 batteries for my key fob.. As for some strange reason it eats them at a rate of 1 every 4 days..
MarcB
  Vw Golf
Cleaned The Windows, Hoovered the carpet and topped up screen wash, coolant & checked oil.
Now looking to buy 4 new Michelin PE2's ;)
Attempted to fit my exhaust tips while I save for a miltek
But they seemed to be more ballache than expected so took them off and now waiting for advice over on 197.net
SC03OTT
  Mk 8.5 Golf GTI
Got my lights adjusted. They now point at the road, not the sky. Being able to see is great.
Adjusted my bonnet (about 100 times) to get rid of the (uneven) gaps between the bonnet and top of the headlights. FINALLY!
