2004 ph2 172
I'm aiming to build my own cage before too long, and I'm wondering what's best when it comes to bending 44 and 38mm CDS.
The two options as far as I know are
1. "Rotary Draw" bender, which requires expensive dies, (the framing and hydraulics I can build myself with no problem), but I'm looking at £200 per dimension...
2. "Press Bending" which usually sees a hydraulic jack and a set of dies for far cheaper.
Pros/Cons
With Press bending - if you want a good result - you have to pack the tube with sand (PITA) but given that it comes with a huge range of dies maybe that's something I can live with. The added joy of putting the press tool in the center of where you want your bend seems to make life easy.
With a Rotary Draw Bender you don't need to piss about with sand, but the tooling cost is high, and the calculation of bend start/end is a bit of a bugger to get right.
At the moment I'm tending to lean towards a hefty press-type bender - for the 6 or so decent bends I need I can live with sand - and with all the other dies I have a good use for it in the future.
What do you guys recommend?
/Nick
Vids:
Rotary Draw bending: http://www.youtube.com/watch?v=XFs4iUxpfzY&NR=1&feature=fvwp
Press type bending with sand fill: http://www.youtube.com/watch?v=GWT3N3m4bE4&feature=related
Pros/Cons
/Nick
Vids:
