What negative camber do you guys run on lowered cars
Car  evo 6rs/clio 172
I have put the camber bolts in the frt struts
Set to -2 camber and when pushing on left bends you get a rumble from the n/side frt wheel
I am guessing bit be the drive shaft hitting in the diff
I have been told -2 deg is ok on lowered cars like mine on cooksport springs
Only other mod is 20mm spacers
Any ofyou guys running -2 or more on there lowered car with any issues
Only rumble I got was from the bearings needing doing. Fine since with -1.83 camber. Going for -3.2 next week. That's on Cooksports
I can't get them lower than -2.2 camber on the frts
Something is odd as you are meant to be able to run positive camber if required
Any ideas please
