So your saying 197 cams in a 1*2 can make more power that after markets if run with correct mods?
Ah okay, sounds promising! Guessing you would still get 5k kick as well? Might have to look into it
Sorry to ask but what is an RS2 ?
Without bodies like this thread is asking?just under 250 is my official record NA
About 100 then, because you'd be on carbs or injection lol
Never mind:banghead:Eh? Standard car is injection and single body as opposed to bodies. Rs2 retains that (and cruise control etc)
Expensive but simple
I've done a couple where the port shape and size has been completely changed in both the head and inlet manifold. It's the level of work I would only really do for a high compression build though. A little bit over the top for a stock bottom end. Mostly my heads are worked to include an enlarged exhuast port (ph1 style) and a tidying of the inlet, then matched to the inlet to be used (be that ITBs or reworked stock manifold)
Here is -J- graph before and after RS2. You can see the "5K kick" (which would be better named a "sub 5k hole" really)You could easily map it to still be equally gash under 5K if you wanted though, and then just have the gains at the top end.![]()
Tell me more? Might treat the van unless as I suspect its gonna cost a fortune..
