What shims for rear toe adjustment?
  Track 172 Cup
I had my car set up a while back at Blink and I needed some rear shims too sort out the toe but I'm looking for shims and don't want too buy the wrong ones. Below is my printout I was given and as you can see the rear toe on one side is out or in lol so I'm going too have it redone soon as I'm having new track rods/ends done on the front so may as well have the rear sorted and checked. So could anyone help me out as too what degree or percent shims I would need to correct that toe.
Mr Trailer Man
Either a 10 or 20 minute shim you need from Pure Motorsport.
Obviously 20 will bring it down to 0'08 and 10 will be 0'18.
20 minute being a closer match to the left side of 0'11.
  Track 172 Cup
Are they fairly easy too fit? Assuming that I get it the right way round haha.. had a quick read on the pure fitting instructions but always sounds easier on paper.
imprezaworks
  Mk5 Golf GTI :)
I don't know mate, I can't remember. I'm sure if they are fitted wrong it's an arse to re fit. Is it not a pain to initially fit them? I might be getting confused with sonething else
  Track 172 Cup
Anyone know which way the shim needs too be fitted I'm assuming the rear wheel is facing into the car with that toe (like towards the front passenger side) ? So would want to fit the shim I have with the narrow part at the rear of the car get the wheel to come out a little.
