what size spacers on trophy for best handling/looks combination?
  XC90, 330d, Trophy’s
I'll double check, but I'm sure mine are single with an Allen key securing point.
im happy with a 195 R888 as they are generous anyhow and come up closer to 202mm anyhow.
​what 205 are you using?
p@blo
  Clio/A3
R888/Pilot Sport Cups. Got some Dunlop wets and they're a similar profile.
Seems to clear OK with even a 5mm spacer so they're not a million miles out. :)
That could be why you are so close, a 205/50/15 R888 is actually 216mm wide, where as the 195/50/15 is actually 200mm wide.
  Audi A5
25mm bolt to hub spacers on the front and 15mm spacers that bolt behind the stub on the rear with 1 or 2 degrees camber is the best set up imo.
