What size tyres on a 172 cup?
Car  Porsche, Caterham, Golf
What size tyres are fitted as standard to the 16" x 7" Speedlines that are fiitted to the 172 cup?
Can you wander away from this and fit a different size? Are there any benefits?
195.45.16 standard
or even 205.45.16
suppose it would give an even wider track on the 205's
Do 205/45/16's fit? i.e No rubbing. even on full lock etc?
Does anyone here run with 205's
I'm thinking of Yokohama Parada 205/45/16's
Good idea or not?
205/40's work as well. Best off sticking to the 205/45's PE2's or GSD3's. Both highly rated
Will running 205/40 help ease the rubbing issue? I appreciate that the width is the problem but will running with a slightly lower profile produce more clearance?
