Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Best thing to do is crack open that black box, pull out all the cables (using a sharp jerking motion), blow on them then its really simple to put the cables back in, job done.
Should help you diagnose any faults with the battery.
Oh dear me. I thought i asked daft questions. As said, one cable goes down to the starter motor , the other to the fuse box , the negative to the chassis
No the normal sized battery hooks under those bits on the bottom mount you can see just under the earth cable - then on the right side there's meant to be a clamp holding it in place
Nip to a local scrap yard and take one from any clio
