clio 172cup
				I've never known a car to eat so many discs and pads I'm starting to think there's an under lying issue !
when I bought the car after a while I replaced all discs and pads and both rear bearings , after a while the rear bearing went again ( probably because they were cheap ) but also that rear caliper was buggered so again replaced that and both rear discs and pads again !!!
On my last mot it failed on unbalanced front brakes and it was shaking under braking so again it had a set of pads n discs on the front and this cured the problem but now like four months down the line it's doing it again !!! Wobbling under braking although sometimes there is a slight wobble anyway surely I can't have warped 2 sets of discs in a year ??! The back brakes don't seem to be wearing all that even either
i had the car tracked and the wheels balanced a while ago and replaced the lower ball joints and track rods
is there something that could be causing all this ?? I don't find it normal for it to keep eating discs specially when I was so cautious about bedding them in , I have noticed a bit more noise also but not sure if its just road noise or something else ! None of the wheels are suspiciously hot after driving either
please help lol I'm losing the will with this car big time problem car is an understatement
