whats involved in changing spark plugs on 182?
Car  182,mx-5 mk1,mev sonic 7
going to change spark plugs what do i need to remove to change them in order please.
coil pack
inlet manifold
leads
Do it when the engine is cold.. torque up the new plugs to 25Nm and use NGK PFR6E-10's :)
coil pack
inlet manifold
leads
And don't overtighten the 10mm Bolts that go into the inlets, as for torque of them.
Fcuk knows, just tight....
A bit of duck tape or something over the lower inlet holes may be an idea after you've remove the upper inlet (plenum stamped with Renault Sport) before you start.
You dont want anything falling down there and landing onto the valves :(
Just out of curiosity...
Do you need to replace the gasket (I assume there is one in there!) between the plenum and the lower part of the inlet?
I'll be doing my plugs this weekend and would need to order a gasket before then if necessary.
Cheers.
Cheers.
I got away with using mine again and its a PTFE one.
PTFE gaskets are reuseable - part of the joy/investment :)
OEM ones are supposed to be replaced, but people do report they have replaced it without any noticeable issues.
